Hello,
We are experiencing the following issue with a 4500L unit:
On one of the chains, the transmit power has decreased (ceased entirely).
We tried swapping the cables and also cross-connecting them. Swapping had no effect, but after cross-connecting, the signal levels on the customer side switched places.
Do you guys perhaps have any idea what might be causing the issue (hopefully it’s not a radio problem, as replacing it would be quite cumbersome)?
