ePTP mode with EPMP 1000 , subscriber reboot
i've a PtP link with two epmp 1000 configured in ePTP Master/ePTP Slave mode, flexible mode, channel width 40 Mhz, Firmware version 2.5.1.
The link seems ok,i've not a very peak high throughput  (60 Mbit/s).
I've noticed that sistematically,after some hours, the SU reboots.
I've tried to use TDD PtP mode, i've not subscriber reboots and the peak throughput is 45 Mbit/s.
Is the subscriber reboot a bug?
How can i solve the problem?
Vrega
Hello,
Would it be possible for you to provide access to the PTP Slave device after detecting a reboot for troubleshooting and data gathering? If so, you can send me the information via private message.
Regards
what diferrent between configuration ePTP and PTP (master /slave).
imam
