Hello,
using ePMP 1000 on multipoint on 40MHz I can reach, at MCS15, an aggregate speed of 230Mbps in ideal conditions.
In ePTP, which is the maximum aggregate speed I can reach?
My tests showed a max speed of 97Mbps aggregate (single direction test) on ePTP 20MHz. Same channel on PTMP I can reach about 113Mbps aggregate.
If I do a test in both direction I can reach 58+58 using 20MHz channel which is 116Mbps, but why can't I have the same speed on single direction?
I would like to have a link which can make 230Mbps if used for 100% download, or 230Mbps if used for 100% upload. Is it possible?
My tests are in a real world environment, but very, very, very clean spectrum (-92 noise floor)!
Thank you!
