When I try to update the ePMP GPS unit, it gives me “Error. Unpack failed, damaged or wrong format package”. I have downloaded the file several time on multiple PC’s and still get this error. The unit has Ver. 1.1.7 on it and I am trying to upgrade it with ePMP-GPS_Synced-v1.2.3-2.tar. Please help.
Stacey,
The file you download from our website, https://support.cambiumnetworks.com/files/epmp you should be able to upload to the ePMP GPS unit. (AP) There is no need to un-zip or un-tar a file before you upload the file to the ePMP AP. The radio will take the “ePMP-GPS_Synced-v1.2.3.tar.gz” file as a whole and upgrade the radio.
Corey, I removed all ePMP from my network due to frustration. I am now trying this once more. I have tried to upload that package to my radio with a Mac and Windows machine. Both give me the same error.
Stacy,
Sounds like a remote session would help in understanding why you are having issues upgrading your ePMP radios. You can contact us via phone: http://www.cambiumnetworks.com/support/contact-support
or via a online form: http://www.cambiumnetworks.com/support/open-a-support-case
and someone from our support team will call you back and schedule a remote session to see what is going on.
I am also having this problem with 2.3 and 2.2 firmware packaged upgrading the AP unit from 1.1.6 RC13
Am almost ready to send these units back and just stick with my ubiquiti stuff
Hi raytaylor,
Can you please contact our support engineers so they can assist you? Or please drop me a note with your number and I will call you as soon as possible.
Sriram
I kept retrying and eventually got the firmware to load
