Under statistics ethernet you can view uptime. Is there a way to get this with SNMP?
Cannot find it here.
Hello hci,
You can find the Ethernet Uptime via SNMP using:
whispBox-->whispBoxStatus-->fecStatLinkUptime ( .1.3.6.1.4.1.161.19.3.3.1.149)
There's also a Aux Ethernet Uptime for 450i which can be found here:
whispBox-->whispBoxStatus -->fecAuxStatLinkUptime ( .1.3.6.1.4.1.161.19.3.3.1.150)
Hope that helps!
-Al
Is there a way to get it in total seconds instead of a formated string? This is not so easy to convert to seconds.
"6 days, 12h:57m:12s"
