Been trying to get some VLANS up and running on my network. After days of bench tests, i decided to try it live.
Picked an AP with few SMs, configured VLAN on the AP, and then configured only 1 SM. The rest remained without any vlan config.
As soon as i enabled VLAN on the AP, all the P10 SMs running 8.1.4 and 8.1.5 had ethernet lockups, even though they were not configured on any VLAN. The P9 units running 7.3.6 were fine. Had to disable VLAN in the AP, then LUID into each SM and reboot it.
Anyone have any idea why this is happening, and how i can resolve this issue?
First try upgrading to 8.2.2 or 8.2.4
jwelch wrote: First try upgrading to 8.2.2 or 8.2.4
Yes, definately upgrade to 8.2.2 or 8.2.4.
Both fixed *lots* of ethernet lockup issues.
