I’ve searched the forums a bit and it doesn’t look like this is possible ?
Any way to quickly/easily get location data from cnM into google earth ?
If there is a way to export data in lat/long from cnMaestro, it might work (I believe google earth pro = desktop google earth):
Well… not a great solution but it works better than expected. Will do the trick in a pinch.
Thanks!
