Hello!
Is it possible to export from all units Ethernet CRC problems into one file? We are using devices PMP 450 and 450i.
SW version: 15.1.2
CnMaestro version: 1.5.0-r12
Thank you
Br
Istvan
Hello!
SW version: 15.1.2
Thank you
Br
Istvan
I need to check with my team.
By the way you are running a very old version of On-Premises.
We released 1.6.0-r5 OVA and latest package is 1.6.2-r11
Please update your On-Premises with latest where we have improved and added new features.
Rupam
Hi
Thank you for your answer.
We are going to schedule this upgrade.
Do you have any informations about the CRC export? Is it possible to do with this version (1.6.2-r11) of cnMaestro?
Br
Istvan
Hi ,
Can you please elaborate on what exactly you want to export when you say CRC problems for Ethernet interfaces for PMP 450 or 450i. A screenshot should help us. Then we can confirm whether this is there in 1.6.2-r11 or not.
KR.
Hello
I have attached a print screen. I would like to export CRC Error counters from all devices.
Br
Istvan
Hi ,
Currently cnMaestro supports only RF statistics for ePMP/PMP devices and Ethernet statistics are not supported.
Hence you cannot export the CRC errors data from cnMAestro.
KR.
Are you planning to develop this feature in a future version of cnMaestro?
Br
Istvan
I can raise a feature request in cnMaestro so that engineering team will consider for future releases.
Hope that should be fine with you .
