Hi.
I'd like to know if it is possible to export/import PMP Equipment Templates in LINKPlanner. And how to do it.
Kind regards,
Gabriel
Hi.
Kind regards,
Gabriel
The templates are saved in the project file. If you want to use the templates between files then you can select the templates in the table view and right-click -> copy before pasting in your new project. You can also save the project containing the templates as a project template.
To do this, click File -> Save As and choose the "LINKPlanner Project Template (*.ptptemplate)" format. See http://linkplanner.cambiumnetworks.com/doc/project_templates.html.
Andy
