Just a warning… Doesn’t connect after upgrade to 4.5.4. Revert back to 4.5.4 R16 and it comes back. Dropped a whole network because of this. F200 or other N based SM’s seem fine.
It is also entirely possible you are facing the GPS issue and when the sync is lost, the AP is dropping all the clients after the sync hold off timer has expired. Could you try our 4.5.5 version that I have posted here on the community?
Thx
Sakid
The beta definitely helped. Sorry for not updating sooner.
