I had a Epmp1000 hotspot 2.4.. and I try to update firmware from 2.5.3 to 2.6. File was update successfully, but when I reboot the device, don´t run anymore. the LEDs will flash from top to bottom. What can i do to recovery?
Hello orssatto,
Usually, the LED pattern you describe indicates the unit is in SM mode, and scanning for an AP. It may have lost its original configuration. Can you access the unit using the fallback IP 169.254.1.1?
Regards
