Migrating about 400 subscribers to CBRS and it would be great if cnMaestro had some feilds for device information that integrated into the process or could run reports against. AGL, azimuth, downtilt etc. Id expect to enter this in the device details under the configuration tab when you drill down to a device.
Hi ,
You can export the location related data by going to Inventory page and the same can be imported in a new server by importing the CSV file in the inventory page. No need to do this manually by going to configuration page of each device . The sample CSV file ca be downloaded in the inventory page by clicking the import button.
Hope this is what you are looking for .
KR.
