Firewall and Proxy Issues
Most profile request problems are caused by firewall or proxy server settings. http://community.cambiumnetworks.com/t5/LINKPlanner/How-to-Obtain-Path-Profiles/td-p/38869 covers the basics of configuring LINKPlanner to obtain path profiles and viewsheds, but some users still experience problems due to their network settings.
Proxy Server Authentication Errors
LINKPlanner only supports “HTTP Basic” authentication, so if the proxy requires anything else, LINKPlanner cannot connect. This is most often caused by a setting with Microsoft's proxy server, which by default only supports NTLM authentication. The preferred solution in this instance is to enable Basic authentication on the proxy.
What IP addresses does LINKPlanner connect to?
LINKPlanner requests data from the following locations:
- http://linkplanner.cambiumnetworks.com - To check network connectivity, news, updates and remote patches.
- http://pathprofile.cambiumnetworks.com - For viewshed and profile requests.
The IP addresses are dynamic, and they may vary from region to region.
Diagnosing Problems
When a profile request fails, the cross is shown in the bottom-right of the main LINKPlanner panel (Figure 1 - Profile request error).
Figure 1 - Profile request errorFigure 1 - Profile request error
Right-click on the icon to display the Progress dialog and click on the “Details >>” button to see more information (Figure 2 – Expanded Progress Dialog).
Figure 2 - Expanded Progress Dialog
The dialog shows that the profile request failed. Double-click on the row in the table to jump to the related error message (Figure 3 - Request Error Message).
Figure 3 - Request Error MessageFigure 3 - Request Error MessageMore information can also be found in the LINKPlanner log files.
To locate the log files on Windows:
 - Click Start -> Run (or Windows Key + R)
 - Enter "%APPDATA%\LINKPlanner" in the "Open" text box
To locate the log files on a Mac:
  - Open Finder and then click "Go" -> "Go to Folder"
  - Enter "~/Library" in the text box and click "Go"
  - Navigate to the "~/Library/Application Support/LINKPlanner" folder
There may be multiple files starting with “cambium_linkplanner”. These are the recent log files. “cambium_linkplanner.log” is the most recent file, then “cambium_linkplanner.log.1”, and so on.
If you still have problems obtaining profiles then email linkplanner@cambiumnetworks.com and include a copy of the log files and details of the steps that you have tried.
