In cnMaestro and on support.cambiumnetworks.com we have 4.2.2-r5 ?
Any info about this release ?
Pshemo
Release note location has changed.
Please get documents from URL https://support.cambiumnetworks.com/files/cnpilot-tech-ref/
Auto Cell
Auto Cell size is an automatic, self-tuning mechanism that balances cell size between APs to guarantee
coverage while limiting the RF energy that could extend beyond the organizational boundary. Auto Cell uses communication between APs to dynamically set radio power so that complete coverage is provided to all areas, yet at the minimum power level required. This helps to minimize potential interference with neighboring networks.
This feauture is not supported by cnmaestro (on premises), what happen if I use it? I got “not in sync” message? When will be cnmaestro updated?
Since these parameters are not supported in cnMaestro, please use override option. With this option we should not see “NOT IN SYNC”.
