please help me with the updated firmwere of force 300-25 radio as my device is not logging in locally and showing to update the firmwere of the device.
- cambium.png (21.1 KB)
Please take 4.5. to upload it to the radio in the recovery mode.
Then upgrade it one more time from normal UI.
Thank you.
I will tell you that the force 300 is crap, you will not find anyone to tell you that the equipment works well and without any error.
wrote:
I will tell you that the force 300 is crap, you will not find anyone to tell you that the equipment works well and without any error.@Tewsbehappy
Hello,
Have you had any negative experience with F300s?
I've checked but didn't observe any Support Tickets opened under the e-mail address your account is created on.
If you could give us more details I believe we will be able to solve your issue if it exists.
P.S. I've sent a letter to you as well.
Thank you.
