I need to know if the ePMP 5 GHz Force 180 and the ePMP 5 GHz Force 200ARS can operate in router mode, PPPoE and with specified VLAN especially VLAN100 and VAN200.
I also want to know the different between the 180 and the 200ARS and also the operating distance of the devices.
The Force 180 and Force 200 are essentially the same radio except they have different antenna gains. The Force 180 has an antenna gain of 16 dBi while the Force 200 has a 25 dBi gain for the 5 GHz model and 17 dBi for the 2.4 GHz model.
Both radios support router mode, PPPoE and VLANs.
The distance depends on deployment and channel conditions. I suggest you use our free LINKPlanner tool to predict the performance of each radio for a given deployment.
