In the top lef corner of the Force 180, I have power, eth and 4 spaces for the force of the signal printed instead of LED. Is this normal ?
The're not even LED on the ethernet, no way to see if device is up on the field.
Ok, now I feel stupid. Reversed network cable on the PoE so the device was not running and the color of the LED cover is the same as the whole unit so it look line only a printing without LED while power off but once the unit powered, we see LED through the case.
Sorry for the noise.
Glad it worked for you. Let us know how the equipoment performs in the field.
