What is a good product for mounting the ePMP Force 180 directly to a wall? I'm going to order a MikroTik quickMOUNT to try, but I'd like to know what others are doing.
[With the ePMP Integrated radios, I've been using the RF Elements NB-ePMP product, and it is fantastic. With the Force 180, however, this bracket does not work. I understand they are making a new version, though.]
The canopy ones look interesting. I'm getting real creative trying to get the Force 180's to mount on anything flat. Lots of Home Depot trips to the plastic conduit isle. I used the RFE ones on the old integrated radios and they were awesome. Perhaps a little overkill! Really wish Cambium put a ball joint on there and an option for a couple screw holes. Would be real easy to integrate that into the current mount.
In fact, the Force 110's need a redesign as well. Hoping the Force 200 gets better. I challenge the designer of any of these mounts to get on a ladder or tower and with one hand attach the radio to anything... I need to hand it to Ubiquiti here for listening to customers and designing some nice mounting options on their new radios.
