I have a Force 200 PTP Link, updated the AP without any problem.
When tying to update the SM it tells me I have to first reboot the radio, I have done that several times and it still keeps saying I need to reboot first.
Any clue ?
Any clue ?
Been there, done that...
You can find post on this topic, problem memory space.
My case was the same when tried upgrade via web gui. Only way was if factory reset was made.
Try, if you can, and already didnt try, upgrade through cnmaestro ( it seems that way is working).
@cperalta wrote:...the SM it tells me I have to first reboot the radio, I have done that several times and it still keeps saying I need to reboot first.
hanks
When I've had this happen, I've been able to upgrade via cnMaestro. I still had to reboot it, but right after a reboot, cnMaestro upgrade worked. The way I figured it (I don't know if this is correct or not) but the way I figured it was that by NOT connecting to the GUI, it didn't use up that memory. So reboot - DON'T LOG INTO SM - and cnMaestro upgrade.
PLEASE LET US KNOW IF THIS WORKS OR NOT.
