Ok, does the Force 300 support GPS sync for freq reuse in PTP links or not?
Hi jakkwb, No it does not.
@jakkwb wrote:Ok, does the Force 300 support GPS sync for freq reuse in PTP links or not?
The Force300 - while it's current incarnation is a PTP link - is designed & built more like a Force200, meaning they are built more like an SM/CPE, with no GPS in them. Down the road, when the software matures, they will have other modes - including ePTP modes, but also SM modes and will be able to connect as an SM to a ePMP Access Point. So - no, there isn't a GPS built in.
However, there will also be a 3000 Access Point coming, with GPS Sync and with Filtering. So these will basically be like an ePMP2000, but a newer "AC" version of it. The 3000's will have GPS sync (and the dynamic filtering) and will support the frequency reuse in PMP and PTP modes.
