Force 400c and NetPoint NP5-DP-3FT deployment in Indiana
In Plymouth, IN, Fourway.net, a local ISP facing the challenge of deploying new backhaul links over unlicensed frequencies in a high-interference area, successfully achieved an 80 MHz channel width on the 5855 MHz frequency, attaining very high modulations thanks to the new AX firmware. By leveraging a NetPoint NP5-DP-3FT antenna paired with the Force equipment, they achieved an impressive RSSI of -53 dBm despite noise levels reaching up to -60 dBm.
Testimonial
"We received our first link last week. My team went out to install it on the tower—I believe it was on Friday. We couldn’t believe the results! Honestly, we haven’t found another product that performs like yours!!! We’ve made some slight changes to our plans since we last spoke. We decided to place this link on a tower with heavy interference from other companies. We figured that with 3-foot antennas, we could cut through that interference. And that’s exactly what happened! We went from a link running in the mid-60s to the low 40s!! Plus, the SNR jumped to nearly 50 dB! That tells me everything is running perfectly! It was also super easy to align and install! I couldn’t ask for a smoother process!
Right now, we’re running this link over 7.5 miles or almost 12 kilometers. Here are the results…
This link is also operating in the high band (5855 MHz) on an 80 MHz channel. The signal, modulation, and quality are flawless—it’s the best link in our entire network. We’ve already purchased more antennas so we can keep deploying on other towers.
It’s a blessing to have found you and the opportunity that this equipment brings."
Quentin Gawronski
CIO
