How is the Frame Calculator used in the 6.1 release for the 900 Mhz Advantage Platform?
If you are running all your 900 APs on hardware scheduling, then you don’t need to use the Frame Calculator. The Frame Calculator is only needed for setting parameters in a mixed cluster – one running APs on both hardware and software schedulers in the same frequency band.
