Could someone explain to me in English… how to use the Frame Calculator?
I’ll assume a lot of the fields are self explanatory (software version, scheduling, platform, etc).
From what I gather and how I’ve used it, the fields I concern myself with are the downlink data %, control slots, max range - the fields that would affect your timing on a Canopy AP. When you compute the results, really the only value you need to be concerned with is Uplink Rcv SQ Start. You want to make sure the difference between this number on one configuration and another configuration is less than 250 to maintain proper sync.
I’m sure Jerry or someone else more knowledgeable will chime in with some more information, but from what I understand that is basically the run down of it.
