If I approach 100% on the UL will that cause a hit on my VoIP performance for these customers? Should I change to 50/50? I REALLY wish there was a 65/35 setting seems like a sweet spot.
The uplink frame time will always be displayed as 95+% until Cambium fixes the reporting but that causes this. What you are seeing is normal behavior.
@carullos wrote:If I approach 100% on the UL will that cause a hit on my VoIP performance for these customers? Should I change to 50/50? I REALLY wish there was a 65/35 setting seems like a sweet spot.
if you've got your QOS setup properly, you shouldn't see a problem until your extremely over saturated. the QOS affects the frames at the scheduling level to make sure they are delivered in a timely fashion
