Frequency problem?
Hello all,
We are using 5.7Ghz Canopy.
We have total 6 Advantage APs with CMM.
All the SMs are also upgraded to 8.1.5.1 4 months ago.Previousely it was 7.2.9 where there was no problem at all.We are now facing the problem related with frequency most probably we think.We are using all the recommended freq. with minimum of 20MHz difference.We encounter this type of problem frequently.We tried all the possibilities but still problem is the same.We are also too frustrated and irritated due to this problem.
If there is somebody who can help us to solve the problem? or give us the idea how we can solve this?
Thanx in Advance and hope we will find the solution.
8.1.5 is not a stable version. Upgrade to 8.2.2 and see if that helps.
8.2.2 is nearly as stable as 7.3.6 but not quite. There are still issues with VLAN and NAT as well as a few others, but it’s much better than 8.1.x
8.2.2 p10 ap’s don’t work well with p8 sm’s.
I was able to reproduce the
issue in our lab using the P8 SM and P10 AP. The engineering team has
fix in place for this issue, and they are putting the final checks on
their code. We have found an issue with the P8 FPGA of SMs talking to a
8.2.2 AP (any variety).
vince wrote:
8.2.2 p10 ap's don't work well with p8 sm's.
Could you be more specific? Thanks.
we have been working with tier 2 tech support to resolve this disaster of an upgrade. It screwed us big time.
but if you have p10 ap’s they wont work well with p8 sm’s regardless if the firmware. but 8.2.2 on p8’s sm’s is is horrible, they have to be rebooted daily.
