Hello guys, I would like to know what happens if I enable "Frequency Reuse" if I'm not currently using Frequency Reuse? I mean: is there any performance degradation if I enable Frequency Reuse "Front" or "Back" without having any other AP in the field?
I would like to know that because I want to setup one AP and without any service interruption I would like to use frequency reuse enabling another AP behind it, but in the future.
@Guilherme wrote: What changes in the radio behavior, between "no reuse", or "front/back"?
LOL. If you're asking specifically what changes from a technical standpoing, then I bet Cambium is going to say "a bunch of secret proprietary things change". :) I think Cambium has figured out the magic of GPS Sync and Frequency Reuse that others in this segment haven't figured out, so I don't expect that they want to divulge too many inside technology secrets. :))
I wonder why it's an option then. Not doubting that it has no effect on the radio's performance but seems odd to have the option to turn it off/on if that is true.
