Frequent Registrations 8.2 AP to 7.2.9 900Mhz CPE ??
This is a New POP with a single V8.2 P10 900Mhz-AP on a MTI 120 HPol external antenna.
We run 7.2.9 or 7.3.6 everywhere. This is our first P10, 8.2 AP.
This is the first customer on this AP, and the CPE has registered over 60 times in less than 24 hours.
I’ve disabled 2X mode on the AP and rebooted it and the CPE has Registered 6 times in the past hour.
AP Session info
LUID: 002 : MAC: 0a-00-3e-xx-xx-xx State: IN SESSION (Encrypt Active)
Site Name : xxxxxx
Software Version : CANOPY 7.2.9 Jul 23 2005 01:49:03
FPGA Version : 070605 (DES, Sched, NO DFS) P9
Session Timeout: 0, AirDelay 133 (approximately 3.70 miles (19551 feet))
Session Count: 6, Reg Count 6, Re-Reg Count 0
RSSI (Avg/Last): 1661/1663 Jitter (Avg/Last): 2/1 Power Level (Avg/Last): -65/-65
Sustained Uplink Data Rate (SM): 20000 (kbit)
Uplink Burst Allocation (SM): 500000 (kbit)
Sustained Downlink Data Rate (SM): 20000 (kbit)
Downlink Burst Allocation (SM): 500000 (kbit)
Low Priority Uplink CIR (SM): 0 (kbps) Low Priority Downlink CIR (SM): 0 (kbps)
Rate : VC 18 Rate 1X/1X
CPE sees the following in AP Eval:
Current entry index: 2
Index: 2 Frequency: 915.0 MHz ESN: 0a-00-3e-92-75-07
Jitter: 3 RSSI: 1612 Power Level: -66 Beacon Count: 12 BRcvW: 1 DFS: 1 FEC: 0
Type: Multipoint Avail: 1 Age: 0 Lockout: 0 RegFail 0 Range: 6517 feet TxBER: 1 EBcast: 0
Session Count: 6 NoLUIDS: 0 OutOfRange: 0 AuthFail: 0 EncryptFail: 0 Rescan Req: 0
FrameNumber: 703 SectorID: 0 Color Code: 15 BeaconVersion: 1 SectorUserCount: 0
Frequency: 9150 NumULHalfSlots: 11 NumDLHalfSlots: 35 NumULContSlots: 2
2x is disabled on the CPE.
AP is not synced (yet). All of our other AP’s are. I can’t ‘see’ this AP from any of our other Towers, and the Spectrum analyzer on this AP and CPE (when the AP is off) shows the entire spectrum at -85 or better, so I don’t ‘think’ it’s a interfernce issue.
AP Max range is set to 10 miles. 2 Control Slots, no 2X, 915 Mhz, I’ve tried all three of the ‘standard’ channels as well though - no difference.
This sub is near the edge of a ‘cliff’ facing the AP; There’s a small amount of foliage on the CPE side, nothing on the AP side, about 45 meters clearance on most of the link except for the last ~150 meters before the CPE.
The CPE is mounted at ~6 meters.
I just noticed while typiing this : Why is it that the CPE reports the link distance at 6517 feet and the AP reports it at 19551 feet ??
Google Earth shows the shot to be 3.71 miles, so the AP looks like it has it right - the CPE is off by a factor of EXACTLY 3 !!
Could this problem be related to a bad bounce? Or is it a compatibility issue between 8.2 and 7.2.9.
Link tests during install:
Stats for LUID: 2 Test Duration: 2 Pkt Length: 1522
Downlink RATE: 1737728 bps
Uplink RATE: 509184 bps
Downlink Efficiency: 100 Percent
Max Downlink Index: 100
Actual Downlink Index: 100
Expected Frag Count: 6788
Actual Frag Count: 6788
Uplink Efficiency: 100 Percent
Max Uplink Index: 100
Actual Uplink Index: 100
Expected Frag Count: 1989
Actual Frag Count: 1989
Current Results Status
Stats for LUID: 2 Test Duration: 4 Pkt Length: 1522
Downlink RATE: 1738368 bps
Uplink RATE: 510976 bps
Expected Frag Count: 13581
Actual Frag Count: 13581
Expected Frag Count: 3992
Actual Frag Count: 3992
And the only one of the many link tests I’ve run this AM where the Up/Down was not above 95%
Downlink RATE: 718848 bps
Uplink RATE: 508928 bps
Downlink Efficiency: 41 Percent <------------- !!!
Actual Downlink Index: 41
Expected Frag Count: 2808
Actual Frag Count: 6797
Expected Frag Count: 1988
Actual Frag Count: 1988
Any suggestions please… :cry:
B
My first effort would be to upgrade the firmware on both units. AP should go to 8.2.2, but only because you can’t take it back to 7.3.6. SM should go to 7.3.6. If you still see trouble, let us know then.
I would think that multipath reflections should give you a further measure, not closer, and also not a factor of three. Seems quite odd.
