at time when the Motorola Helpdesk need some Information i must use the CNUT Tool, because this function are not integrated in Prizm.
i hope you can grant the my request
We’re running Prizm3.1 and the gather support tool is included, located under Help > Technical Support
I’m pretty sure it was also available in Prizm3.
are you sure that the PRizm 3.1 can gather the same information? i have spoke yersterday with motorola and they say no!
Patrick
Last time I required support they told me that tool does the same thing as the support tool in CNUT.
