General error occurred on web access ePMP1000
Have "General error occurred" problem on my ePMP 1000. SSH avialable. Reboot, downgrade, doesn't work. SW version 3.5.2. In forum this problem was solved on 3.5 SW. But i have this too.
Hi Egor,
Please try to clear cache and cookies in your browser.
Thank you.
Hi, Fedor!
I tryed clear cash&cookies, tryed another browser, tryed another PC. It didn't work. I have same promblem on 2 ePMP 1000 AP. When release 3.5.3, may be it will help us?
and also in ssh cli "show config" didn't display information
Egor,
It is not a known issue. And I don't think 3.5.5 will solve it for you.
Could you please open support ticket through Cambium Support please?
https://www.cambiumnetworks.com/support/
Please add me to CC.
Thank you.
Hi Fedor. We are solved this problem. reset cnMaestro and reset ePMP 1000 after this all work.
У меня появилась похожая проблема. Тоже выдает ошибку "General error occurred" на ePMP 1000. Перезагрузка не помогла. Доступ по SSH есть.
I had a similar problem. It also gives the error "General error occurred" on the ePMP 1000. The reboot did not help. Access by SSH is.
