Regarding the new antenna for ePMP1000 & 2000, what is the best way to attach the GPS antenna cable to the sectoral antenna body and prevent the cable leaving the slot?
we used clear gorilla tape, seemed to work fine
We used Silicone. Be Sure and put some duck tape in a few places to hold it down while the Silicane sets up. It let use run the cable in the slot nicely.
