I have 6 APs Installed ,all of which has a GPS Sync however there is no Long / Lat information available for the GPS Coorditantes.
Also 4 out of six times logging into the AP i have to restart it if i need to make any changes , each time i log in it shows a red icon stating that information is missing for the security key or SNMP RW is missing , then if you restart the AP all information is visible and you can also select the save option thereafter…
Patrick - GPS Long/Lat information is not current available in the latest System Release 1.3.4. We are planning to have this functionality available in the upcoming release which is in a few weeks time. In the meantime, you can manually program the coordinates on the radio GUI under Configure->System.
