GPS sync Problem
Hello,
I am facing problem in GPS at few sites. Suddenly GPS goes down and hard reboot (Powering the device off and then on) required getting it back again. Can you please explain the reason for that and the solution to overcome this problem?
Please note, running farmware is 2.3.4 and i have tried to resolve this problem by uploading the same farmware in GPS Upgrade section, but not solved.
Hello Nayan,
Can you please confirm the following:
1. Firmware version of the GPS chip from the Monitor->GPS page is listed as AXN_1.51_2838
2. GPS antenna is labeled as Unictron P/N P005198 G023
Regards,
Luis
