While adding a new grounding block, near the main service ground, I believe I felt voltage on one of the ground wires attached to either the 450i body or one on the two 600SS.
Did not have a chance to trace it back to which device it was connected to but will do so as soon as the weather breaks.
Is the length of my #10 ground wire too long and if so will adding a grounding rod, closer to the radio, bonded to the main service ground rod fix the problem?
Do I have a bad 600SS?
Do I have a bad 450i?
Install Overview
#6 Ground Wire attached to mast
450i radio installed with shielded CAT5e w/ drain wire w/ shielded connector
#10 Ground Wire attached to 450i radio
Cambium 600SS installed at radio
#10 Ground Wire attached to 600SS
Cambium 600SS installed at building entry
#6 Ground Wire runs down the mast about 25 feet and is attached to a grounding rod the #6 Ground Wire then continues an addition 50 feet or so to the main service ground.
The three #10 ground wires run parallel with the #6 ground wire all the way to the main service ground. They are NOT attached to the first ground round they are only attached to the main service ground rod.
All CAT5e cable runs from the POE injector to the radio are shielded w/ drain wire w/ shielded connectors.
The POE injector in connected to a APC power strip and the power strip is connected to a APC UPS w/ line conditioning.
