We offered following adaptor to convert Dragonwave antenna for PTP820 use:
N110082L011A
PTP820 Dragonwave Antenna Adaptor for Cambium, 11GHz
N130082L004A
PTP820 Dragonwave Antenna Adaptor for Cambium, 13GHz
N180082L009A
PTP820 Dragonwave Antenna Adaptor for Cambium, 18GHz
N230082L002A
PTP820 Dragonwave Antenna Adaptor for Cambium, 23GHz
Step 1:
Carefully clean and grease the O-ring mounted on the Dragonwave antenna using the grease tube supplied in the PTP820 Dragonwave antenna adaptor kit box
step 2: Gently slide the PTP820 Dragonwave antenna adaptor onto the Dragonwave antenna. Make sure that the hook is facing up and close the latches firmly.
Step 3: If the O-ring is already mounted to the PTP820 side of the Dragonwave antenna adaptor, just remove gently the adhesive tape. If the O-ring is not mounted, place the O-Ring supplied in the Dragonwave Interface kit onto the PTP820 Dragonwave interface. Make sure the mounting direction is correct, as shown in the section view.
