I have a high power 2400 access point running the latest firmware but when I use the updater tool to try to turn on hardware scheduling, it says it is not supported.
I have posted the stats page, can someone tell me whats wrong ?
Device Information
Device type
2.4GHz - Multipoint - Access Point - 0a-00-3e-20-92-a8
Software Version
CANOPY 7.2.9 Jul 23 2005 01:49:03 AP-DES
Software Boot Version
CANOPYBOOT 3.0
FPGA Version
020205 (DES)
Uptime
01:04:51
System Time
07:27:09 11/29/2005
Last NTP Time Update
00:00:00 00/00/0000
Ethernet Interface
100Base-TX Full Duplex
Access Point Stats
Registered SM Count
2
GPS Sync Pulse Status
Receiving Sync
Is this an Advantage platform AP?
It looks like u have a classic 2400AP .In this case u need to get in touch with Motorola or their ACSP/ACRS to buy Conversion To Advantage Platform.
This would allow u to get the hardware scheduling.
FOR SMs u do not need this.
Please go through following & decide which one suites u.
http://motorola.canopywireless.com/promo/moveup/
So does that mean that only advantage AP’s can use Hardware Scheduling ?
I believe that has the “ver 8” board… you can send it in and get them to swap it out with a ver 9, which support HW. Cascade will do it for 1200? + or -.
To see if you have an Advantage capable board telnet into the radio and type ‘ver’. If it says platform 9 then you have a board that can get the software upgrade to Advantage. If it is a P7 or P8 then you will need to participate in the trade in program and upgrade the hardware.
