If i enable hardware scheduling on an AP and not on all of the SMs (the non +p8s) will the software scheduled SMs will work?
Yes it will.
P7 hardware will handle 7.3.6 and HS.
Adolfo
No. Not unless you use the cnut tool and up date the older version sm units
No. No. No. :? Hardware scheduled radios can not communicate with software scheduled radios. Therefore, if you have an AP on HWS, all of the SMs you want to talk to it have to be HWS. The same holds true for SWS.
You can, however, collocate HWS APs and SWS APs. It’s good idea to use the Framing Calculator in this situation though.
Aaron
