Have advantage AP but cannot get more than 7M throughput?
I have a 5.7 advantage cyclone ap but cannot get more than 7m throughput through it. 80% downlink. i thought these could do 14M. Any ideas?
14Mbps is a theorical value, you will need all sm to be at 2x to get that(generally not posible)
but 8-9Mbps aggregate is real.
Depends on your AP downlink %…try increasing from 50-75 or 80%.
Set your BURST speeds to the MAX (500000)
AP and SM both need to be Advantage to see full potential throughput.
You will not see 14Mb through a single SM, because of overhead and your Downlink %… its just the way it is…somethings will never change :slight_smile:
