The subject says it all,
Mac line of router is BC:E6:7C:xx:xx:xx
Tried the default 192.168.11.1 with no luck.
*Edit*
I am 0 for 3 in my first box of 10... not looking good.
*Edit*
Hi ,
Can you try https access, https://192.168.11.1 ?
If it doesn't works , please raise a ticket on our support site , https://support.cambiumnetworks.com . Will look into it.
Regards,
Nilesh
Yes I have tried both http and https with said ip address.
Thank you for your reply and I will raise a ticket.
