Help me!
Does PTP 820foo_bar support 12+0 with XPIC, 80 MHz channel sizes, protection, MC-ABC, LoS MIMO, and instantaneous recovery?
Can you help?
That's how it starts.
I don't know!
So here's what I do:
1. I check out the  pertinent PTP 820foo_bar release notes here: https://support.cambiumnetworks.com/files/ptp820/.
(By the way, foo_bar can be either S, C, G, or NMS!)
These release notes are extensive--they have information on supported scripts, features, limitations, etc. They also have lists of fixed bugs and lists of bugs that are still open.
Another thing--these release notes are searchable! Just enter in a search term, toggle through the document, and you just might find what you need.
2. Using LINKPlanner, I try to plan a link with PTP 820foo_bar support 12+0 with XPIC, 80 MHz channel sizes, protection, MC-ABC, LoS MIMO, and instantaneous recovery.
If LINKPlanner doesn't let you plan it, the product probably doesn't support it!
Of course, if #1 and #2 above don't work for you, please contact Cambium Networks in the forum or at customer support!
http://www.cambiumnetworks.com/support/contact-support/
I hope this helps!
Dave
