We are putting up a P10 AP that currently has 8.1.5. I would like to put 8.2.7 on it but since it’s out of warranty I can’t get the software from Motorola. If I understand the procedure correctly I need to go 8.2.4 then 8.2.7. Where can I find this software?
If you have purchased ANY motorola Canopy hardware (SMs or APs) in the last 12 months, you can use the MAC address off of those units to request the software upgrades.
That being said, there are some people on this forum that upgrade straight to 9.x and report no issues.
wifiguy wrote: That being said, there are some people on this forum that upgrade straight to 9.x and report no issues.
8.1.5.something -> 9.0 no problems
9.0 is very much recommended for stability and packet rate
