I have a link (2.89 miles away) with a strong Signal and good jitter (2) on the SM side but, on the AP side, it has a jitter of 10 or greater and keeps re-reging. The sm side has a reflector on it and is set to 1x. What other kinds of things can I do to try and lower the jitter on the AP side?
Is this a full cluster or a single AP? Which band? I have seen many links that have a good path in one direction but poor in the other (diffraction loss, multipath, etc).
Aaron
I had the same problem…i swapped freqs on the ap and the problem seems to be less noticable.
