I have 9000SMCs and have several customers where the Jitter is 5 or higher. I upgraded to 18dbi antennas and it hasn’t eliminated the problem. RSSI appears to be fine (1200 or higher). What can I do to lower the Jitter? Is there a better (shielded) antenna I can use?
IF you are running in Hardware Mode and you have 2x enabled that might be why you are seeing higher jitter rates. Try disabling it to see if the jitter rate goes down. My Personal connection at the house has a jitter between 5 and 10 and I have zero issues.
-j
I’m running all my SMs in Software mode. Where is the 2X or 1X mode … haven’t seen that. Given this … any idea regarding jitter?
