I´m trying to configure Hotspot with CNMaestro. I can configure Hotspot voucher and free without google and it works perferct. However, wee need your help for these questions:
1.-The first thing that I would like to confirm if it is a bug, is that once the portal has been created, if you make changes it does not apply:
- If you configure it by vocheur and you want to change to free it ignore you and it stays in voucher mode ...
- If you add you google or facebook before to create the portal, it does not apply
Do we need to delete that portal and create another one of the other type?
2.-Could you send me an example about how to configure the google social login?
3.- For those cases where the client wants his personalized hotspot, making the registration by mail, is it possible to use the gmail authorization or have to prepare an internal hotspot using a radius?
Regards.
