hi, i have in the same site 6 AP 5.7 and 5 BH few in 2.4 and 2 in 5.7
but i have problems to sync all them.
i have a CMM, but only have 8 ports to Sync
are you resolved similar problem?
Sync the 8 5.7 devices via the CMM and then get a second CMM to sync the 2.4 BH’s.
8 5.7’s in the CMM
the other side of the 2.4’s are they in a CMM ?
I saw at lastmilegear.com a 16 port CMM by Cyclone. It doesn’t say if all the ports send the sync pulse, but it’s worth a look.
I’ve also heard if you make your own cables, you can plug pins 1,2,3,6 into a switch and 4,5,7,8 into the CMM to pass sync and power. I haven’t tried it though.
I would go with keefe’s suggestion - get a second CMM.
Aaron
do a search for a SyncPipe for the odd timing signal… I think the Cyclone is only an 8 port with passthrough for connectiond to a switch and thus has 16 ports…
