How Can I configure epmp 1000 /force 200 to function as WiFi Access Point Hotspot?
- New Doc 10_1.jpg (619 KB)
Hi there.
From the ePMP family, there is only one device that you can use as WiFi Hotspot an is the ePMP Hotspot. See the next picture:
I think for Hotspot applications you can get better results with the cnPilot E series.
The Force180, Force200 and now the Force300 work better for last-mile access or in certain scenarios as PTP Link.
for ePMP 1000, you can convert to hotspot and vice versa.
I test that before. see this
for Force 200, you can use it as AP but not Hotspot.
I don't know whether an AP can be combined with 3rd party Hotspot service
WISPr (pronounced “whisper”, stands for Wireless Internet
Service Provider Roaming, is a draft protocol submitted to
the Wi-Fi Alliance allowing for hotspot service.
