Is there a reset button somwhwere on the SM to set it back to factory default? Any help is accreciated. Thanks
Please follow these instructions. NOTE! Alternatively, you can use a USB type B plug to short pins 4 and 6 and have the same desired effect.
Holy smokes, this is not a simple button push solution I was hoping for :( Since I am a complete newbie I guess I have to move out of my comfort zone and figure out how to make a 3 pair connection. Thank you for your help. It really is greatly appreciated.
Short Pins 4 and 6 on the RJ11 Port by using a coppy wire to connect between ports 4 and 6 then do a power cycle. remove the sort after a minute to allow it to be accessed by default IP. All configs remain the same.
