At present the performance of a PTP 650L link can be predicted in LINKPlanner by configuring the link as for a PTP 650S and setting the bandwidth to the appropriate option for PTP 650L (either 10 or 30 MHz). The BOM will show the parts for a PTP 650S and will need to be adjusted for a PTP 650L, by changing the part number for the PTP 650S End to that of the PTP 650L End, remove the PTP 650S Upgrade Limited Range to Full Range License, if present and add the 10 MHz to 30 MHz Upgrade License, if required.
