How do I read the Spectrum Analysis I ran from SM?
Here are pics of the Analysis:
Part 1:
http://www.demonshouse.net/myimages/wor … spec01.JPG
Part 2:
http://www.demonshouse.net/myimages/wor … spec02.JPG
Ive read the docs, but its doesnt really explain it very well.
Thank you!
the green lines are the power level on the indicated frequency
the yellow ticks show the max power level its seen
the lower the negative number; the stronger the signal
it would appear starting at 5800mhz you are seeing -54dB which is a very strong signal & then the signal falls off to the noise floor at 5840mhz
hope that helps…
drdrew,
Thank you!
That helped a lot :slight_smile:
I think each line is actually an average of the 10 MHz to the top and bottom of it; representing a 20Mhz chunk.
