On October 12, 2016 17:13 I've open a support ticket asking Cambium Networks to patch cnPilot's firmware to allow assing /32 address to it, the same issue affect also ePMP1000's firmware.
Following i transcript the ticket with the suggested solution that Cambium Networks accepted and implemented
--- BEGIN ---
Hi, i'm in the need to use assign to cnPilot IP with a /32 netmask. IPs are assigned by a dhcp-server running on our
MikroTik core routers, there's no problem using linux or MikroTik clients. I've some R200 routers running 4.0-R2(201508071420): Product Information Hardware Version V1.3 Loader Version V3.05(Apr 29 2015 18:41:37) Firmware Version 4.0-R2(201508071420) and some upgraded to latest firmware version 4.2.3-R4(201606031245): Product Information Hardware Version V1.3 Loader Version V3.07(Aug 20 2015 17:38:07) Firmware Version
4.2.3-R4(201606031245) all of them are affected to these issue.
On 4.0-R2 fortunately there's a telnet daemon running so I was able to investigate the issue and solve it, on newer version seems that telnet was taken away and so i cannot do nothing (please reenable telnet daemon or better ssh daemon on cnPilot, I'll open a request or that). busybox's udhcpd has a bug (see https://bugs.busybox.net/show_bug.cgi?id=4604 and http://bugs.debian.org/652573 for a better explanation) prevent him to configure gateway if netmask is /32 (255.255.255.255), adding 3 line on /sbin/udhcpc.sh solve the issue (see at the end).
What i did
Connecting via telnet to cnPilot I discovered that manually adding gateway all work as expected:
# ip addr ls dev eth2.1 14: eth2.1@eth2: mtu 1500 qdisc noqueue state UP link/ether 00:04:56:04:19:71 brd ff:ff:ff:ff:ff:ff inet 172.31.0.253/32 brd 172.31.255.255 scope global eth2.1 inet6 fe80::204:56ff:fe04:1971/64 scope link valid_lft forever preferred_lft foreverip route ls
255.255.255.255 dev br0 scope link
# 10.0.0.247 is a router connected to the default gateway 192.168.16.8
traceroute -n 10.0.0.247
traceroute: can’t find interface
# Add default route manually
ip route add 192.168.16.8/32 dev eth2.1
ip route add default via 192.168.16.8
ip route ls 255.255.255.255 dev br0 scope link
192.168.16.8 dev eth2.1 scope link default via 192.168.16.8 dev eth2.1
traceroute to 10.0.0.247 (10.0.0.247), 30 hops max, 38 byte packets
1 192.168.16.8 0.546 ms 0.321 ms 0.289 ms
2 10.0.0.247 0.755 ms 0.453 ms 0.384 ms
but trying to add route via web interface (Network -> Routing) (that’s the only way possible with newer firmware)
nothing happend, trying on a 4.0-R2 I can see that adding route via web interface (Network -> Routing) as following:
Web interface says that: Current Routing table in the system No. Destination Mask Gateway Flags Metric Ref Use Interface Comment 1 192.168.16.8 255.255.255.255 0.0.0.0 0 0 0 0 INTERNET(eth2.1) 2 0.0.0.0 0.0.0.0 192.168.16.8 0 0 0 0 INTERNET(eth2.1)
all seems ok, but no traffic flow on wan, checking via telnet no route was added:
# ip route ls 255.255.255.255 dev br0 scope link #
Solution
I've copied /sbin/udhcpc.sh in /tmp, edited it, just before:
echo "route add default gw $i dev $interface metric $metric" route add default gw $i dev $interface metric $metric
i've added:
if [ "$NETMASK" == "netmask 255.255.255.255" ]; then echo ip route add $i dev $interface ip route add $i dev $interface fi
and manually launch udhcpd as:
# udhcpc -s /tmp/udhcpc.sh -i eth2.1
solve the issue:
# ip route 255.255.255.255 dev br0 scope link 192.168.16.8 dev eth2.1 scope link default via 192.168.16.8 dev eth2.1 metric 1traceroute -n 10.0.0.247
1 192.168.16.8 0.477 ms 0.346 ms 0.290 ms
2 10.0.0.247 0.818 ms 0.498 ms 0.422 ms
so please release a firmware that configure routing to default gateway if netmask is /32 and reenable telnet or ssh access to cnPilot
— END —
Help request
Same very issue, surpresely, is also present on ePMP1000 and as reported from Cambium Networks' support also on PMP450 and PMP650 equipments (I don't have a PMP* to check myself) and seems no one notice that before me.
On ePMP1000 ssh/telnet access is enable but it doesn't lauch busybox' shell so I cannot investigate like done for cnPilot and solve to myself the issue, but I'm pretty sure that it's not different from cnPilot one: it doesn't add route to default gateway on the device before adding route to 0.0.0.0/0 resulting in error. Combium Networks ask me to share to you what I did to fix cnPilot's bug saying that if more people ask to fix the same issue on ePMP1000s they'll do it, so, please, help me asking to solve the issue!
Many thanks for your help, Micky
