In defining templates there doesn’t appear to be any way to change the SNMP Subnet, Community and Read/Write settings on an SM.
I know this can be set for NEW SM’s that are accepted into PRizm, but what if you’ve accepted them and then want to CHANGE these parameters??
Are we supposed to visit each SM individually and set these so that Prizm can then access everything via SNMP on a new community string.
Anyone?
Try CNUT, you should be able to change those parameters in there.
